Topic: Components By Supplier Category Module - Search Error
| By: Osman | Posted on: Sep 4 2025 at 02:40:34 PM | | Hello, when I search for "Maleme" in the relevant module, the search fails, meaning no results are returned. MRP is not working correctly. In Win10, this process does not work at all. In Win11, it works once and then not at all. MRP is lagging. When I search for materials in the Suppliers section, no results are returned. We would like to request an update for this error. | |
| By: Guest | Posted on: Sep 5 2025 at 04:03:57 PM | Sorry. I don't know what 'Maleme' means.
Where are you searching? Are you using the Search box in the bottom right corner? Or are you clicking the Column Title cell and select the 'Filter" option? | |
| By: Guest | Posted on: Nov 30 2025 at 07:26:56 PM | Hello,
I am searching in the search box located at the bottom right of the section grouped by category and supplier under the Components module. The results are not working properly or are not working at all. Also, the system is case-sensitive when searching. I kindly request that you fix this issue. I request that you ensure that the same product appears even when searched for in lowercase letters. | |
| By: Support | Posted on: Dec 2 2025 at 06:15:31 AM | See Here
Search Error | |
