Topic: Customise Report
| By: Guest | Posted on: Feb 3 2020 at 05:19:17 AM | | Can built in reports be customised? For example PO's and shortage reports. Not just adding a logo, actually changing widths, fonts etc. | |
| By: Guest | Posted on: Feb 3 2020 at 08:45:14 AM | | Just to clarify - what i meant by this is that if you print a shortage report, some of the widths do not work, "Balance" and "Lead Days" appear as one. | |
| By: Support | Posted on: Feb 4 2020 at 06:50:24 AM | In the shortage forecast - You can drag the edges of the columns to make them wider. Next next time you open the report the widths should be remembered. So this should not be a problem.
| By: Guest | Posted on: Feb 13 2020 at 02:29:51 AM | I can't seem to make thois work, the "Balance" and "Lead Time Days" are joined together in the report. In my case balance is -150, lead time is 5 days, shows as -1505.
I moved the columns, but no change.
Also, can the PO report be customised? I.e. text added for terms etc? | |
| By: Support | Posted on: Feb 13 2020 at 03:28:34 AM | Question about Shortage Forecast Balance and LeadTime "Joined" together. Sorry I can't reproduce this. Can you send me a screen grab?
Question about PO Report? Do you mean the actual purchase order? If you do mean the actual purchase order then there's a comments box at the bottom left of the PO for adding your terms for a specific PO. Or, go to the very bottom of the menu to Setup/Tools>Setup>Supplier's Tab and add an optional 'Footer' that always appears at the bottom of every PO. | |
| By: Support | Posted on: Feb 13 2020 at 05:24:03 AM | Thank you for sending the screen shot.
Sorry. My mistake. You are correct. I missed where you said "Print".
On screen in looks fine but when printed the text in the LeadTime column is aligned to the left causing the data in both columns to appear without a gap.
We'll have tis fixed very soon.
