Topic: Error on Exit
| By: Dave | Posted on: Mar 16 2021 at 05:39:18 PM | I'm a new user trialing this out. Just noticed an error I'm getting described below.
With no tabs open, when clicking the upper right (X) or doing the menu (///) -> Exit, the program closes fine. When I have tabs open and click the (X) the program closes fine. When I have a tab open and do menu (///) -> Exit, I get an unexpected error: Items.cs Error... "Collection was modified; enumeration operation may not execute". I'm on Windows 10, with just installed Minimrp 5.0.104.0 (S)
I just want to make sure something is not wrong with my DB or program or I'm creating a problem in my DB with these errors. Am I the only one with this issue? I don't mind just using the (X), but am worried about the parts I've imported/created during the trial. | |
| By: Guest | Posted on: Mar 17 2021 at 05:58:35 AM | Hey. I see the error too
I never heard of this before. I guess most people are using the X button. I Also use the X because I've never noticed it either.
If I'm not mistaken mini mrp runs 99% of the time in a disconnected state meaning it is not connected to the database except when you 're actually reading or writing the database. So, when clicking the save button the connection is made, the data is saved and minimrp immediately disconnects from the data. Program crashes or just switching off the computer unexpectedly shouldn't damage the database.
But in the venry bottom left of the menu is a backup button. You can never make too many backups. | |
