Topic: Goods Overdue - Minor Bug
| By: Guest | Posted on: Nov 11 2020 at 04:07:04 AM | If we have two lines on an order for the same item, one due on one date, the other due another date. If the first line is overdue, say a day or two, it shows up orange in the list (correct).
Once we recieve it, the order is still outstanding because of the other line, but it will show overdue still, unless we change the date to today.
Regardless of the required and received date, once recieved it should be cleared from making the hole order seem overdue.
| By: Guest | Posted on: Nov 11 2020 at 07:14:24 AM | Just to add, if you change the original date to some date in the future, this clears the highlight.
If you then change it back to original date, the highlight stays removed. As it should be.
Also, does not appear to happen in every case. | |
| By: Support | Posted on: Nov 11 2020 at 09:26:46 AM | | Thanks for posting this. I'll have it looked at soon. | |
