Topic: Text size on large monitors
| By: Steve | Posted on: Feb 15 2019 at 01:45:42 AM | Hi All,
I'm trying to increase the text size for use on a large monitor, MiniMRP dose not seem to respond to increasing the text size in windows 10 when other app do, any other ways?
Steve | |
| By: Guest | Posted on: Feb 15 2019 at 08:51:23 AM | This worked for me. Right click on windows 10 desktop and select display properties.
see the option to "Change the size of text, apps and other items". Change to 125%
Although on my 4K display even 150% was a tad too small so I changed the resolution to 1920x1080 and left the fonts at 100% | |
| By: Steve | Posted on: Feb 15 2019 at 10:22:35 AM | That's what I tried, but then that messes my CAD program up, I was trying to adjust the text size of MiniMRP only.
Steve | |
| By: Support | Posted on: Feb 15 2019 at 11:20:07 AM | | Steve. Where are you trying to adjust the text size? In the desktop shortcut's compatibility features? or where? | |
| By: Steve | Posted on: Feb 16 2019 at 02:47:07 AM | Hi Support,
Yes, I have tried setting the DPI settings in the start icon, if I set the scale to 150% MiniMRP is great but what ever options I try it effects my whole system which messes up my CAD system.
Setting the overall windows setting to 125% is the best compromise I've found so far.
My monitor is 30" dell @ 2560 x 1600 resolution. | |
| By: Support | Posted on: Feb 16 2019 at 08:38:30 AM | | Steve. In your first post at the very top of this page you said that MiniMRP does not respond when other apps do. What other app? Where does that other app/apps have their font size option? Is it within the app itself or some setting in Windows that affects just that specific app? | |
| By: Steve | Posted on: Feb 16 2019 at 09:20:32 AM | In windows - setting - display - make text bigger MiniMRP does not respond.
In windows - setting - Make everything bigger MiniMRP does respond, but MniMRP needs to be 150% and my CAD system needs to be 125%
I cant find away of setting them independently, its a Windows issue really, but thanks for looking.
Steve | |
| By: Support | Posted on: Feb 16 2019 at 09:38:50 AM | | We'll take a look at font settings within MiniMRP. | |
| By: Steve | Posted on: Feb 16 2019 at 09:41:04 AM | | I'm on Windows 10 pro 64 version 1809 28/01/2019 | |
| By: Steve | Posted on: Feb 16 2019 at 09:41:32 AM | | That would be great. | |
| By: Support | Posted on: Mar 5 2019 at 04:49:02 AM | Steve. Do you want to email us so we know who you are. I'd like to send you an update to test with your Monitor to see if it scales in a way that's compatible with your cad system.
