Topic: V5 - Shortage (Snapshot) and (Forecast)
| By: Guest | Posted on: Jan 25 2019 at 05:13:03 AM | | You did a nice job adding filters to the Inventory and Assembly screens. Would it be possible to add a similar filter to the Shortage List and Shortage Forecast reports? | |
| By: Support | Posted on: Jan 25 2019 at 08:19:47 AM | Sorting and Filtering in the shortage snapshot would be fairly straight forward.
But I'm not sure about filtering in the forecast report.
Filtering on PartNumber, description, category etc should be feasible. But filtering out, for example, suppliers could cause some confusion.
The forecast report shows pending transactions, grouped by item, in chronological order. In theory it could be showing expected arrival dates of the same item from multiple suppliers in the same time frame. If you filtered out, ie excluded, suppliers that would remove those expected deliveries from the report where it would cause a shortage even though items are already OnOrder from the filtered (excluded) suppliers.
I think we need to think about this. I've put it into the suggestion box. | |
| By: Guest2 | Posted on: Jun 12 2019 at 07:29:57 PM | | To piggyback off of Guest's initial post, it would be nice if we could filter the Shortage Forecast by work order number. It could then display all parts only associated with a particular work order for faster analysis of a single job. If a part on the filtered work order (WO:1) was in demand for another WO, I would still want to see that part is needed for another WO. Basically, I would just want it to filter out any items that are not used on WO 1. | |
| By: Support | Posted on: Jun 13 2019 at 04:34:28 AM | @Guest2
Thank you - Also into the suggestion box. | |
