Topic: Where used function
| By: Guest | Posted on: Apr 6 2019 at 08:27:05 AM | I am looking at MiniMRP. I need a the ability to list all of the higher-level BOMs in which an item number appears. For example:
Item Number: 101787
Item Description: Screw, SHCS, M10 x 15
Is used in Item Numbers: 109857, 106574, and 784235
I want to search through all BOMs and list those that contain 101787.
The query should generate: 109857, 106574, and 784235
Does MiniMRP support this query? | |
| By: Steve | Posted on: Apr 8 2019 at 12:58:38 AM | | On the item page there is a "Used In" tab, is that what you need? | |
| By: Steve | Posted on: Apr 8 2019 at 12:58:39 AM | | On the item page there is a "Used In" tab, is that what you need? | |
| By: Guest | Posted on: Apr 8 2019 at 05:28:40 PM | | I'll check it out, thanks! | |
